fuel pressure gauge question - Performance Forum
Monday, April 04, 2005 1:10 PM
ok here is a question.. i read the faq for nitrous and understand that overtime the fuel pressure in the system is likely to fall.. so .. where would be the best place to tap into teh system to install the pressure gauge.. ya know.. to get the most accurate reading?
Memeber since 4/2002
Premium since 1/2005
Garret t3 turbo charger for sale.. $75 plus shipping
jeep wrangler hard top for sale.. 97-up.. rear defroster and smoked glass..
$900 or best offer.. e-mail for more info
Re: fuel pressure gauge question
Monday, April 04, 2005 1:17 PM
Fuel rail
Monday, April 04, 2005 1:30 PM
shifted.. do you even have a job or are you just on here all the time???
Monday, April 04, 2005 1:32 PM
LOL, I'm at work
Monday, April 04, 2005 1:34 PM
must be nice.. anyways.. you said the fuel rail.. i asume there is a t to install or a spot where i can put the sender in.. i guess it would help if i tell you im going with autometer c2 gauges and they come with some sender thing.. thanks alot man
Monday, April 04, 2005 1:36 PM
No, you'll have to drill and tap the rail like the rest of us without schrader valves. You could cut and splice it into the feed line to the rail (one that goes in the side without the FPR). That will give you an accurate reading as well.
Monday, April 04, 2005 1:38 PM
hmmm.. dificult to do or no??? i know how to work a drill, but i dont have a drill press
Monday, April 04, 2005 1:49 PM
Its just aluminum, but its easy to screw up. You'll then need to get a tap the same size as the threads on the sending unit. Very easy to drill through though, just don't drill too big of a hole. (You need to tap it after you drill it, so it has to be slightly smaller than the tap).
Monday, April 04, 2005 1:50 PM
ok.. hey one more man.. real quick.. if i wanted to install nitrous, where would i tap into for the fuel solenoid???
Monday, April 04, 2005 1:52 PM
The rubber fuel feed line that goes into the drivers side of the rail. Just cut the rubber part and put a Tee in there.
Monday, April 04, 2005 1:53 PM
and can i use that same t to get the fuel pressure???
Monday, April 04, 2005 2:15 PM
Yes, you'll need a 4 way T then.
Monday, April 04, 2005 2:37 PM
so then that is the simplest way i can figure.. thanks alot shifted..
