RSM crank pulley for ecotec - Performance Forum
Monday, April 04, 2005 12:36 AM
i was wondering if you need to buy a new belt for this pulley
Re: RSM crank pulley for ecotec
Monday, April 04, 2005 1:00 AM
Yes you would need to purchase a belt.
Monday, April 04, 2005 5:27 AM
rsm = oem size so you wont need a new belt
if your looking for a ecotec pulley check here ecotec pulley kit
___________________________________________________________
-=Motegi mr7 chrome 17'' for sale 1000$(canadian) +shipping e-mail me=-
Monday, April 04, 2005 5:44 AM
The eco crank puley is indeed factory size at RSM. I doubt anyone rolling an eco needs a belt by now.
All crank pulleys are in stock and waiting for a new home.
Monday, April 04, 2005 10:39 PM
I got one of the first ones that were made almost a year ago and it helps the high end reving speed, with a lighter flywheel it really takes off, my belt is needing to be replaced im at almost 70k
Monday, April 04, 2005 10:43 PM
yea my 04 eco is coming up on 61000
04 sunfire auto, mid 15's n/a, and still going
Thursday, April 14, 2005 10:24 AM
how hard is the install?
i got mine today so ill try to put it in sat
Thursday, April 14, 2005 10:44 AM
the crank is kinda a pain to get at and you gotta line the puller up right or it will hit the frame rail
Thursday, April 14, 2005 11:15 AM
three prong puller or two?
Thursday, April 14, 2005 12:42 PM
should be a 3
Thursday, April 14, 2005 4:16 PM
RSM pulleys are nice quality and OEM size. Still waiting on the 2200 alternator pulley though.........
I'll have a sig someday....................
Thursday, April 14, 2005 4:27 PM
I'm going to try and put my OEM size RSM crank pulley in tomorrow, but whats all this business about needing a puller or something? I thought it was just one bolt and pretty simple to do....?
Thursday, April 14, 2005 4:43 PM
why would u need a pulley puller loosten the nut but dont remove then remove the belt then unbolt crank pulley and pull out no pulley remover needed its not necessary and the stock one slides right back in
Thursday, April 14, 2005 8:35 PM
can u just pull the belt off?
Thursday, April 14, 2005 8:52 PM
I've never needed to use a puller on the Ecotec pullies. All the ones I have installed have just wiggled right off with. The 2.4 pulley on the other hand uses a puller.
Thursday, April 14, 2005 8:55 PM
I just got mine today FINALLY after a month, it took us about 30 min to put it in very easy install..and nice response from the pulley.
<img src="http://www.j-body.org/registry/twiztid04cavy/car051.JPG">
Thursday, April 14, 2005 9:11 PM
right how do you remove the belt?
just pull
or does the tensioner pulley need to come off?
Friday, April 15, 2005 7:04 AM
We losened the tensioner and pulled the belt off while putting pressure on it.
Friday, April 15, 2005 8:58 AM
one last question
is there a specific tq for the bolt when you put the pulley on?
Friday, April 15, 2005 10:54 AM
hmmm..I hope not since we did torqe to any specifics for mine!
Friday, April 15, 2005 3:13 PM
proper torque specs for ecotec crankshaft pulley according to GM shop manual is 74ft lbs and then 75 degrees
Friday, April 15, 2005 7:14 PM
75 thenk 75 degrees? meaning turn three quarter turns past where the tq wrench clicks?
Friday, April 15, 2005 8:06 PM
75 degrees which is like a little more than a 6th of a turn not 75% of turn
Friday, April 15, 2005 9:03 PM
I just installed mine a couple hours ago. Installation wasn't too bad, although the whole belt came out which is exactly what I didn't want to happen. I loosened the tensioner pulley bolt and pushed it up out of the way, then I could get the pulley off. Pretty simple, but I;m still trying to figure out if my bolt for the pulley itself is actually tight enough....I used an impact and it felt like it was tight enough, but the bolt actually spins with the pulley, doesn't seem right to me, Can anyone let me know if the bolt is suppose to spin with the pulley (at idle)??? Thanks.
Performance wise, I always hear people talking about feeling a gain in the higher RPMs but if anything it feels like it helped low end power. Either way throttle response seems much better also.
Saturday, April 16, 2005 8:11 AM
put my pulley in
took about 45 minus pulling the fender liner off and moving thelift up and down
also installed front sway bar bushings
