MSD8913 tach adapter trouble - Performance Forum
Sunday, April 03, 2005 4:15 PM
ok, this is what the directions say to do.
<img src=http://webpages.charter.net/cody350/msd8913.jpg>
now, on a older post, people said to hook into this wire:
<img src=http://webpages.charter.net/cody350/thispinkwire.jpg>
ok, the problem is, i still cant get it to work...im assuming because the wire people said to hook ino in that pic was a trigger wire for the ECU, and the tach adapter needs a coil voltage wire. or perhaps i needed to cut the pink wire, hook one end of it to the solid red wire of the MSD box, and the other green and red wire to the other end of the pink wire??? im confused cause so far i have had no luck getting this to work.
hoping someone remembers how they did this so i can finally get my shiftlight working. thanks!!!!
<a href=http://jbnw.org><img src=http://home.comcast.net/~fitzgerald.d/RR4.bmp>
Re: MSD8913 tach adapter trouble
Sunday, April 03, 2005 6:30 PM
what i did on my 2.4 was went into the fuse box and taped into the fuse marked Tach. Weather or not u have a fuse in there tap into it, then make sure ure set on 4 cylinder.....
works great for me....
Dave
Sunday, April 03, 2005 6:32 PM
why do you need a tach adaptor?
my tach worked fine... it was programmable from 1-12 cylinders.....
course it was stolen LOL
LE61T PTE6262 Powered
Monday, April 04, 2005 12:31 AM
never mind, dauber was in chat, for those of you setting this up, you have to cut the pink wire, and the green and red from the adapter goes to the end by the valve cover, and the red wire from the adapter goes to the pink wire from the loom.
i have a stock tach and wish to use a adjustable shift light, so an adapter is needed.
Monday, April 04, 2005 10:58 AM
if i was a mean guy.... i'd change those pics over to some nasty old man porn or something equally disgusting
i'm just glad those are hosted through my service provider's webspace so i don't have to pay for that bandwidth.....
Monday, April 04, 2005 12:24 PM
im sorry bro, i started a new thread so i could get some answers since people stopped replying to the old.
i dont have any webspace, i should buy some when i get some cash.
go ahead and take it down, i should have asked
