RK Sport Upper Mount
RK Sport Lower Mount
Mandrel Bent Custom 2.25" Cat-Back Exhaust
Dual Aero Turbine Mufflers
Autotrans Interceptor
RSM WAI
RSM 62MM Throttle Body
RSM Crank Pulley
RK Sport Copper-Beryllium Spring Inserts
Magnaflow Hi-Flow Cat
Weapon-R 4-2-1 Header Ceramic Coated by JET-HOT
Magnaflow 31" Magnapack Resonator
Hypergrounded
This is forr the eco btw....
So essentially, exhaust, an intake, and a tb are the only hp mods listed, in which case you MIGHT see 160hp at the crank, but I doubt it.
For Sale:
'01 SFGT springs $50CAN
Getrag '00-'02 2.4 8000kms $800
Let see:
-a stock Eco makes 140hp to the crank
-calculating 10% of lost of power in the tranny (which is pretty low considering your car is automatic) you would need 178hp to the crank (to put 160 to the wheel)
-that's a 38hp gain
I say not possible with bolt-ons
<img src="http://pages.infinit.net/aceclan/Cavalier/signature.jpg">
98 Cavalier RS with a 2000 2.4 swap
i say no
![](http://i134.photobucket.com/albums/q109/99redz24/camarosig.jpg)
add some internals to that list and you can get over 160whp.
Are ya trying to figure out wheel or crank HP. With a header, intake, exhaust and throttle body you'd be at 160 or a little more at the crank maybe. But not at all at the wheels. What you have done is aloud your engine to breathe easier which does help, but ya need something internal to run faster like cams or more underdrive pulleys to get some real gain without boost.
Vengeance Racing (Honor or Death)
2004 Cavalier
Supercharged by RSM Racing and Vortech
hp 255
Mods see my profile and go to my car
nope I put down 148 whp with my mods and I am a manual, I will bety 500 bucks you wont and secondly ask njshondakilla he put down 129 whp minus his head
LE61T PTE6262 Powered
5whp? The 62mm throttle body is PROVEN to add 10whp and has been dynoed. I would say close. Don't get discouraged by the 2.4l guys
It's just now cutting it's teeth.
MAYBE 160 crank hp, maybe if you're lucky... Probably around 140-145whp.
Aaron wrote:5whp? The 62mm throttle body is PROVEN to add 10whp and has been dynoed. I would say close. Don't get discouraged by the 2.4l guys ![](/global/images/emoticons/ab.gif)
I am VERY skeptical of this claim. I can not see the TB on its own being good for an additional 10 hp, nevermind at the wheel. POSSIBLY if it were complementing a turbo setup, or something of the sort, but on an NA platform, with just that as a mod (without complementing mods such as FULL exhaust, and other bolt ons) I really cant see this being true. Prove me wrong, and I'll gladly eat my words.
nope
![](http://registry.gmenthusiast.com/images/matt38y3/sig.jpg)
There was a before and after nydo graph of stock eco on the dyno and then added WAI and 62 MM TB while the car was still on the dyno, redynod and DID gain 10 whp out of it, but that is definetly not typical. with those mods defientely not 160 WHP, nto even close out of an auto
Alero SS wrote:Aaron wrote:5whp? The 62mm throttle body is PROVEN to add 10whp and has been dynoed. I would say close. Don't get discouraged by the 2.4l guys ![](/global/images/emoticons/ab.gif)
Excuse me???? I'm a 2.4 guy here, and I'm just stating the truth here. Motor for motor the 2.4 has more power to start, and I would not say I have 160 WHP, maybe close. He is a auto so he is looking at a good 15-18% tranny loss. I'm saying the Ecotec is abad motor or anything because it is not. This motor has surprised me. He asked a question and stating a answer. There is plenty of modded eoctecs out there, but I have not see or heard of any putting that kind of power all motor with bolt on, or hitting 14's all motor.
Darkstars wrote:There was a before and after nydo graph of stock eco on the dyno and then added WAI and 62 MM TB while the car was still on the dyno, redynod and DID gain 10 whp out of it, but that is definetly not typical. with those mods defientely not 160 WHP, nto even close out of an auto
Well already that's not attributable to the tb, as you've added an intake as well. You can't say the intake didn't help the power gains, so in the end how much can you really attribute to the tb? I'm sure I can find posts on here claiming 11hp from the intake alone, does that mean the tb caused a loss of 1hp?
For Sale:
every car is different..
john higgins I would be in the 14's but just dont go to the track lol
quickBOOSTEDecotec wrote:every car is different..
Does not count. You should and I agree, but it has not been proven yet.
John Higgins
So your agreeing with me? I said "close" too.
I apologize if my info was wrong.. tb=10 whp instead of tb/i=10 whp. Still that's good gains for those mods. I was just trying to give the guy some confidence because regarless of gains it's fun to modify and try to reach performance goals
the bored out TB DOES NOT FUGIN PUT OUT 10 WHP, believe me, i just took my 62MM BORED TB FROM RSM off and put my stock one back on, very small difference
now if it was on a boosted cav, i could see it, but not NA, unless it was HEAVILY modified
he just corrected himself if you would read what he posted
i think he mean ten hp not ten whp
well there has been more than one stock cavy dyno at 133 whp
which is only 7hp loss or 5%
so if it were a manual id bet youd be alot closer
I wouldn't say you're putting down 160whp. A mod itself can give you X amount of horsepower but you'll be dissapointed when it's coupled with another.
my 2.4 auto was dyno'd at 140 , with wai , 57mm tb , and 2 1/4" cat back , and lower mount
so youll be hard pressed to get 160 from just those and the eco starts 10 hp down from a 2.4
quickBOOSTEDecotec wrote:nope I put down 148 whp with my mods and I am a manual, I will bety 500 bucks you wont and secondly ask njshondakilla he put down 129 whp minus his head
your exhaust is probably a lil too big until you boost
