Whut's up all.. Alright Quick question for all you 2.4 Owners that have Cams & run Nitrous. I will soon be spraying a 50 into my Z and i've been thinking about getting JPB's performance Cams. Now.. I know if i spray a 75 I need to get a MSD DIS-2 and retard the timing on it.. if i throw cams in my motor that's taking a 50 shot already (otherwise stock motor).. am I gonna needa DIS-2 as well? or should it be fine running that on it's own w/o messing w/ the timing and what not.
-Any info/help would be greatly appreciated.
-Saint Augustine
? And exactly what did you want to know? You should be fine without and ignition box with just cams and a 50 shot. Just get a set of copper plugs, like NGK's, that are a heat range colder for the N20. I run 100 shot without an MSD box with no problems, so a 50 shot is cake.
<img src=http://ourworld.cs.com/jwithspray/Jbeier_sig3.JPG>
gotcha! that's all i wanted to know, I already am runnin' NGK's inpreperation for my 50 shot... i just didnt know if i got cams if i would have to retard the timing b/c they will change the timing a little bit in the motor b/c they are performance... I just didn't know how much it would change it while also using a 50 shot. Just wanna be safe & not blow @!#$ up
-Saint Augustine
