Need an engine - South Central Region Forum
I let someone drive my car not to long ago and i need to replace an engine and everytime i find an engine for my car ( 99 Z24) it gets sold before i can get enough money to buy it.
I have around 900 dollars saved up and if anyone knows where any 2.4's are that are for sale around the DFW area and have relatively low miles on it (preferably under 50k) please let me know
Thanks
What broke in the engine? Why not just have it rebuilt? Did it spin a rod bearing? Or is it just knocking?
95 Cobra
Check out my site
with 900 i would have it built with performance parts. Wouldnt take to much more than that.
it makes a clanking noise whenever its running that speeds up whenever the engine revs up. if anyone lives around irving send me a message because i want to know exactly whats wrong with it.
thanks
If it is making a knocking sound, u probably spun the #3 rod bearings. Was the engine low on oil?
Call 972-294-USED. They have a 99 2.4 engine for $750. They are in Frisco.
275hp & 306tq - 1999 2.2 ohv
13.2 @ 108 mph
-1996 2.4 liter + Turbo + Built motor + Torco + More boost = Lots o' Power
-2000 Mustang GT + 2004 Cobra motor, Whipple 2.3 supercharger,
built rear-end,Dodge Viper spec T56 6 speed, bolt-ons = wheelies at the track!!!!!
Yea the engine was low on oil. also i need to find someone to put it in or help put it in either way because my step dad is to lazy to help me. And ill call that number whenever i get out of school today.
oh and if i spun the #3 bearing is the engine fixable or not?
If you are going to try to repair the engine with a spun rod bearing, you might as well do a rebuild on the bottem end of the engine.
13.2 @ 108 mph
I know but could it have damaged the block because the noise is really loud like if i start it up my neighbor that lives 5 houses down can hear it in her house. and how much would it cost to fix it to where it would run properly or possibly better?
The cost will depend on how much damage was done to the block. You might have only spun a bearing or two. If so, the engine would need to be pulled out and taken to a machine shop. I am guessing that the machine shop would charge you around $300-500 to rebuild the bottem end and assemble the entire engine witth all of the gaskets and new parts.
13.2 @ 108 mph
do you know of any shops that would do it for that price around irving? i live in south irving and i really need my car back. can you tell whats wrong with it without taking the engine apart?
I do not know of any machine shops in Irving. I had my 2.2 built at a machine shop in Arlington called HnH Machine. My bill was $694, but my engine had alot of other stuff done for racing. They have also built two other 2.4s for turbo.
From what you are describing, it sounds like the engine either spun a rod bearing or threw a connecting rod. The 2.4s are notorious for spinning the #3 rod bearing when ran low on oil.
13.2 @ 108 mph
Adler wrote:I do not know of any machine shops in Irving. I had my 2.2 built at a machine shop in Arlington called HnH Machine. My bill was $694, but my engine had alot of other stuff done for racing. They have also built two other 2.4s for turbo.
Yep probably spun more then 1 rod bearing with low oil! Hell I spun 3 and my oil was FULL! If your lucky you can have the shorblock rebuilt it. But I wouldn't start it or drive it anymore will just make it worse.
95 Cobra
Check out my site
i havnt started it in forever but im wondering if there has already been to much damage done to the block to fix it the sound is really loud. Also i need someone that has enough knowledge that can put it in for anywhere from 200-400 dollars if thats reasonable.
Check your Inbox up top.
13.2 @ 108 mph
Hey man damn that sux what happend to your engine happened to me too... anyways if you find another engine ill put it in for you!!!! if i can take your "blown" engine off your hands??? or i can just help you out to put it in and take it out! no charge ........ lookin for a 5 speed tranny too if anyone has one laying around
ohhh and yea since im going turbo i have alot of stuff im selling : RK Header, Cold air intake, 56mm TB Riged it, well full 2.25 exhuast, crank pully, if your interested ohh and ill trade ya you 5 speed for my 4 speed tranny
well later
i might have someone interested in the intake and the header pm me a price for both and individually please
I think im going to go to the machine shop in arlington to see how much it would cost to rebiuld the bottom end and if its reparable. Does anyone know how i can tell if it is reparable.
Also should i put motor mounts in? or just an upper or a lower because i really dont want the car to vibrate to pieces i just want the engine to be a little stiffer. Which mount would be better for this.
ak z24 wrote:I think im going to go to the machine shop in arlington to see how much it would cost to rebiuld the bottom end and if its reparable. Does anyone know how i can tell if it is reparable.
It will have to be removed and taken apart before they can tell you if it is rebuildable or not. Solid motor mounts are only worth the trouble if you are breaking stock ones IMO. They make the car rattle under 1200RPM.
95 Cobra
Check out my site
We found another engine out of an 02 and my step dads supposed to be picking it up today. Is there anyone that will have time next week to put in an engine.
Im trying to get it running again before i go back to school after spring break.
thanks
like i said take it to gtr's shop if you can
wheres that at. and how much would they charge? You have to remember i dont make much money at all right now
