Hitting rev limiter the cause of problems? - Maintenance and Repair Forum
Thursday, December 08, 2005 8:59 AM
Wondering if anyone has hit the stock rev limiter or fuel shutoff on top speed a couple times then saw any problems? Car is soundin like it has a burned exhaust valve. But i just installed a brand new head from Advance a few weeks before i ran it this hard, may have been manufacturing defect.
Thanks guys.
I root for the underdog...figured I might as well be one
Re: Hitting rev limiter the cause of problems?
Thursday, December 08, 2005 9:10 AM
did you properly break in the head? If not you probably broke it yourself...no Manufacturing defect.
Thursday, December 08, 2005 11:56 AM
Yeah broke it in properly
Thursday, December 08, 2005 2:42 PM
what is an exhaust valve and how does a car run when its bad?
Thursday, December 08, 2005 7:35 PM
Do a compression check.
Thursday, December 08, 2005 7:45 PM
Did a compression check proper compression everything that should make an engine run is working properly...except cylinder 1 misfire. This is a tough one....gonna replace the head cause ive gone through absolutely everything.
Thursday, December 08, 2005 7:52 PM
What engine are we talking about?
Thursday, December 08, 2005 8:00 PM
Mike Wayne wrote:Did a compression check proper compression everything that should make an engine run is working properly...except cylinder 1 misfire. This is a tough one....gonna replace the head cause ive gone through absolutely everything.
I was getting misfires a couple weeks ago also. Mine was just bad gas. Check on that before you tear your engine apart again.
Thursday, December 08, 2005 8:04 PM
If (a big 'if') you floated one of the valves, there's
possible piston damage ....
IF that's happened, an 'expert' opinion is recommended ....
Thursday, December 08, 2005 8:31 PM
Brandon Schmidt wrote:what is an exhaust valve and how does a car run when its bad?
A valve the opens to expend the exhaust gases from the cylinder chamber. You can imagine how a car can have problems if an exhaust valve is malfunctioning. Exhaust gases aren't leaving the chamber, or not as quickly, and can cause some problems.
Blown.
Friday, December 09, 2005 8:48 AM
How about checking the spark plug?
Friday, December 09, 2005 4:10 PM
what motor is it?
Friday, December 09, 2005 4:25 PM
I'v hit my rev limiter many times and i havent had a problem yet.
Friday, December 09, 2005 4:34 PM
Ditto, nothing really bad (like holding it there for like 10 minutes), Done it numerous of times on my old Sunbird (probably wasnt a good idea, new head, and it wasnt the best). I'd check the plugs personally, could do the trick. Also is possible, is maybe that the plug wires are not in the correct order. My Sunbird was running a little rough after the head, and i later discovered that the #3 plug was shot, and the wires for 1&3 were swapped, seemed to fix it. If you've got a 2.2OHV, that sounds like an idea.
Saturday, December 10, 2005 5:44 AM
You have done a compression check, as John Lenko suggested and the results were GOOD it just can't be a bad valve!
I wouldn't replace the head as I don't think there is anything wrong with it.
I would tend to think JH and Ender Wiggin are on the right track
It would be nice to know what engine we are talking about.
Have you tried swapping the spark plug from the "bad" cylinder with one from a good one which is not fired from thje same coil.
See what happens?
Alont
