ok so i did the secret cam swap on my 01 z24
first off the cams are timed right so rule that out
ok the car is misfire at an idle badly the scanner read 12 times per cylinder per min.
the car has new plugs gapped right, new coil pack housing and new boots
the temp gauge drops to zero when i floor the car. takes a few min to go to normal. no check engine lights unless it has been idling for about 3-4 min. the engined are only for multiple misfires.
could to computer be going bad?
Sorry...
You have been banned from posting on this site as of 2005-09-21
00:33:32. This ban will expire 2005-09-28 00:33:32 Pacific Time.
Reason: Comments over the top regarding Jordan Kruger and other members in Versus. Also, if you have a problem with a member e-mailing you, do not bring it into the forums.
If you believe this to be in error, please contact us.
