door hinges - Maintenance and Repair Forum
door hinges
Tuesday, October 18, 2005 12:55 PM
Anyone know how to replace the door hinge? How much time it takes and the tools I will need to do it.
Also I had to buy the whole hinge when only the bushies are gone, anyone know what other vechiles had the same bushies so I don't have to keep buying hinges?
Re: door hinges
Tuesday, October 18, 2005 8:18 PM
im pretty sure all 3rd gen jbodies need the full hinge replaced, my old 2nd gen i replaced the pin/bushing, but if you look at the 3rd gens, it just isn't possible. I need to replace teh lower driverside hinge in mine aswell, been procastinating about it for months, from what ive heard the best way to do so i put a jack stand under the door, unbolt the hinge, bolt in the new one without moving anything
Re: door hinges
Wednesday, October 19, 2005 7:00 AM
You don't need to use a jack stand, you don't even have to open the door. Keep the door shut and latched. Remove the fender, and you will simply be able to unbolt the hinges with no real problems. I don't remember the bolt size, but all you need is a rachet and possibly an extension. You can have a friend hold the door onto the car just to be sure nothing happens. Unbolt the old hinge, and bolt in the new one... no special tools needed.
Re: door hinges
Wednesday, October 19, 2005 9:23 PM
Man, sounds like these hinges are a common thing. Both mine and the wife's '99 Z's have the drivers side door sag issue and quite a bit of play if I grab the door I can move it up and down quite a bit. Mine actually is starting to rub against the bottom where it meets the sideskirts! Argh!
J
Re: door hinges
Thursday, October 20, 2005 7:36 AM
Yeah my is dropping now and the front fenders are getting damaged because of this hinge problem
Re: door hinges
Thursday, October 20, 2005 9:09 AM
^get lambos
Re: door hinges
Thursday, October 20, 2005 9:12 AM
Don't get lambos... thats what started my whole door problems to begin with. They are a nice addition to a show car, but they were nothing but a pain in the @ss for a daily driver.
