Hi ok so i have another question how do you know if your motor is missfiring? cause i noticed that when my car is in park it seems kinda jumpy on the tach? any suggestions?
check all you plugs and wires. samething happend to me it also could be bad gas which is what i have know
Fast isn't always good, looks and sound is sometimes better
Imamarine
all around tuneup sounds in order. if your tach is jumping at idle it sounds like your car cant breathe. check air filter, pcv valve, and run a bottle of injector cleaner. also make sure none of your vacuum lines are collapsed in or plugged.
can the PCV Valve get clogged
Imamarine
