wiring problem - Maintenance and Repair Forum
wiring problem
Thursday, September 01, 2005 5:22 PM
Tying to figure out what’s wrong with my car. Sometimes the wipers and the lights wont work on my car.
When you turn on the lights the wipers come on slow and turn on the wipers the lights come on. I haven’t done anything with the wiring it just started happening, has anyone else experienced this. I searched buy didn’t find anything. If it keeps up I m just going to rewire the whole thing.
Thanks in advance.
Re: wiring problem
Thursday, September 01, 2005 6:16 PM
if you can find the wiring diagram for it ill be happy to help i deal with reading schematics at work all day so if you can find a wiring diagram ill be happy to help sort out where they all should be and the you can check to see if there where the suppose to or if there is a relay switch or something that may not be working and causing them to both go on
Re: wiring problem
Thursday, September 01, 2005 6:17 PM
Sounds like your column "stalks" went bad...
The turn signal/headlight & the wiper... I would replace those.
<img src=http://registry.gmenthusiast.com/images/reddevil/Devil.jpg>
Re: wiring problem
Friday, September 02, 2005 7:28 AM
thanks for the input. I will have to get a haynes manual and go through the wiring diagrams
Re: wiring problem
Friday, September 02, 2005 9:19 PM
I think I would agree with red devil more than likely the arm switches are going bad,the symptoms u are having are signs of them wearing out.I would not waste my time searching wiring diagrams.Just buy new arm switches and that should correct the problem.This is not a untypical problem,normally its the light switch that bites the dust with no headlights and just daytimes.Ok
