No oil pressure, overheating, but I have oil... - Maintenance and Repair Forum
Friday, July 01, 2005 6:25 AM
So I was idiling outside a friend's house when I noticed my oil pressure light came on and the car was overheating. I shut it down and checked the oil and I was about 1/2 quart low. I'm guessing its the oil pump or a clogged head gasket. Any ideas?
Re: No oil pressure, overheating, but I have oil..
Friday, July 01, 2005 8:16 AM
put a mechanical oil pressure gague on it , and test it
but sounds like oil pump
Friday, July 01, 2005 10:06 AM
I have a mechanical oil pressure gauge. The oil pressure gauge was at 0 when the light came on. After letting it sit for 10 min I restarted it and I had normal oil pressure.
Friday, July 01, 2005 10:22 AM
how long has it been since you changed oil last ??
sounds like the pump still might be going
Monday, July 04, 2005 12:35 PM
Replaced the pump and changed the oil and I still have the same problem.
Replace the rod and main bearings next? Hopefully all I have to do is drop the oil pan down to replace them.
