loosing power - Maintenance and Repair Forum
loosing power
Tuesday, June 21, 2005 10:06 AM
i seem to be loosing power when i come to a stop. when im ideling i just about loose power. my lights dim and all. i have replaced and upgraded the alternater to 160amp and a yellow top optima. any ideas?
Re: loosing power
Wednesday, June 22, 2005 9:29 PM
check your grounds
http://www.ohiocichlids.com <<<<If you keep cichlids
Re: loosing power
Thursday, June 23, 2005 9:00 AM
grounds are all tight. i checked. i couldnt find anything loose.
Re: loosing power
Thursday, June 23, 2005 9:06 AM
then your alternator is getting weak.
Re: loosing power
Thursday, June 23, 2005 9:11 AM
What kind of stereo do you have. I assume because you upgraded all that, that you have one of those annoying stereos I have listen to when I pull up to a stop light.
Anyways a voltage regulator built inside the alternator can cause your problems.
Get you battery tested for voltage, or if you have a multimeter you can do it yourself. An alternator test you can have autozone do for you, its free.
