help wont start. - Maintenance and Repair Forum
help wont start.
Monday, May 16, 2005 12:56 PM
i have a 01 z24 2.4l. i rammed the car into a pile of dirt while back that set airbags off.
im removed most of the air bag equipment,( steering wheel, passanger, some peices in the front end. removed exhaust system, replaced in new. car started after accident fine and drove and ran fine just mussed up looking. today 2 weeks since last started. placed in new radiator, but lost ac system so yanked out entire system except for pump. unplugged only the pump. air bag system is almost completely out of car. but for some odd reason car wont start. not even pop, just turns over can smell fuel. checked all harnesses. fuses are all in tack. any ideas.
still running too
Re: help wont start.
Wednesday, June 15, 2005 1:36 PM
i had the module checked , cam sensor is fine. today i checked for spark and there is nothing, i dont beleive the injectors are spraying either. any input, i really need some help.
Wednesday, June 15, 2005 11:28 PM
Is the ECM geting voltage? Do you hear the gas pump prime when you first put the key in the run possition? Check all your fusses, under the hood and in the cab.
Tuesday, July 19, 2005 2:19 AM
ok been awhile but i better keep this up. let car sit for month no battery. replaced battery. yes pump primes but no pulse from injectors. no theft light. no spark. confused!!! no codes on scan toolz. im lost. anyideas? GURUS!!!!
still running too
Tuesday, July 19, 2005 1:38 PM
Bad battery cables? Bad plugs? Starter? Bad ground?
1971 camaro 427 --- here!
Stock... and loving every minute of it.
Tuesday, July 19, 2005 3:36 PM
1 tested plugs on 92 cav, they all work fine, 2 it has little over 30k miles on it. the motor turns over fine, no spark no fuel!!!! oh and plenty of ground.
still running too
Friday, July 22, 2005 2:04 PM
ok i never tampered with any of the original wiring or equipment except for the following, removed air bag componates from steering colomn, and front end. changed interior bulbs out with led's. placed aftermarket wheel. removed exhaust system and replaced with header and 3inch piping. replaced before and after sensors on exhaust. removed and replaced frn qtr's and bumpers. removed and replaced headlamps and horn. removed a/c system from car.
ok after all this i had also removed the doors to finish side skirts and prep for paint.
well i unplugged and replugged the passlock system to trip the theft system and walla i got the security light is now actually flashing. (at first i thought this was the original problem but i went through the reset and the light went away.)
ok i checked top make sure the ecm and other components had proper voltage and so on. everything is powered. had the ignition system tested and all is well there.
ok before i did majority of these things the car started and drove like new ( even though i just pulled it off a 5 foot pile of dirt) i got it home and as it sat for awhile i weekly started it just to keep the fluids moved around. after i did the first paragraph it wont start.
The entirewire harness is in excellent shape. only splice i made was to the after cat sensor. which was the wires off the original sensor.
when the key is foward, the fuel pump primes, there is also pressure in the rail. the coil gets plenty of power. the ground to the block also excists.
yet no pulse form the injectors, and no spark. ANY TAKERS!!!!
Sunday, July 24, 2005 3:57 PM
oil sending unit!!!! man how retarded well hell. she runs stupid stupid stupid.
still running too
