#2 and 3 Cylinders no spark - Maintenance and Repair Forum
Friday, April 22, 2005 5:35 PM
A guy i work with has a 93 Beretta with a 2.2 in it similar to my 97 cavy 2.2. His problem is that his engine runs, but without cylinders 2 and 3. Somehow he got it to go 65 which is amazing to me. Anyways, we changed the plugs and wires. Still no spark. So we changed the coil packs. Nothing.
Any ideas? I know there's a metal plate that the packs bolt up to. I have no idea whats behind it.
Suggestions?
<img src="http://images.cardomain.com/member_images/11/web/443000-443999/443183_1_full.jpg">
Re: #2 and 3 Cylinders no spark
Friday, April 22, 2005 6:21 PM
that metal plate behind the coil pacs is the ignition module.....it tells which coils to fire at a certain time
Friday, April 22, 2005 7:04 PM
well if your other coil works that means that everything else is working so you might have got a junk coil or the module is bad. But I've never seen it just take out one coil, but I guess it is possible.
<img src="http://geocities.com/jimmythekid1/gecat2.gif">
Friday, April 22, 2005 9:24 PM
you could also just for a test purpose....swap the coils and see what happens...if 2/3 dont fire at the plug then i would start with a module.....
Friday, April 22, 2005 9:30 PM
maybe nothing from that trigger signal?
Cardomain|Myspace
Saturday, April 23, 2005 7:17 AM
if he had no tirgger signal he woul not have 1,4 working and no injector pulse.
Saturday, April 23, 2005 11:11 AM
I called the guy and told him. I don't know....it doesn't make sense why its basically one coil doing it. I don't know much of how the ignition module works but that seems strange that one coil doesn't work and the other does. We flopped coils and neither of the new coils work in that position. Anyone know if the ignition module is kinda split so part of it does the #2 and #3 and the rest does #1 and #4? If its set up like that maybe its the ignition module. But i don't see it being set up like that.
Saturday, April 23, 2005 11:23 AM
the pins could be bad in the module so it is not grounding the primary of the coil. Realy if the module has power and ground that is really the only thing left.
Saturday, April 23, 2005 12:18 PM
After that module the only thing left is the wiring or the computer....but if the computer is bad it wouldn't just screw up one coil...it would most likely screw more than that up.
Saturday, April 23, 2005 12:29 PM
wiring = power and ground
Computer only controlled spark advance and retard not base timing.
Saturday, April 23, 2005 1:42 PM
oriellys auto parts can test ign. mods for you for free
Saturday, April 23, 2005 1:49 PM
if you have power, ground amd a trigger signal what is left to test.
Thursday, April 28, 2005 5:32 PM
The controller was the problem boys. Thanks a ton...another problem solved.
