all right when i accelerate theres a minor clicking noise its not loud and my dad thinks its a lifter in my motor he tryed to explain it to me he siad the lifter is by the cam shaft and pumps oil
what do you guys think is the problem?
how much is a lifter and what does it do?
its not bad i can live with it but my dad says i should get it fixed to be safe and prevent further damage
thanks for the help
Need more info .. Fill out your registry .. each engine in the J's have different issues and different things that are just normal.
<img src=http://domestictuners.com/banner.jpg WIDTH="400" HEIGHT="75" /img>
Hit 200 NA it broke once, Hit 213 it broke again,
Hitting 300 NA is further away than I thought.
my bad i have a 97 cavalier 2.2 4 cylinder
NOT A Z24
First of all a lifter does not pump oil. It is what transfers the lift of the lobe of the cam to the pushrod in a 2.2L. The pushrod then pushes the rocker arm, which pushes down on the valve spring and valve, thus opening the valve in the cylinder.
The 2.2L is known for this tick issue and is considered normal.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
well how would i go about fixing it because it gets on my nerves
you cant..sell the car and don't buy another 2.2
to solve the ticking noise getting on your nerves do what i do. turn thr radio up load so you don't hear it
