Well at stop lights in drive my steering wheel shakes and so does my dash like a vibrator. I've run injector cleaner. It has been doing it here and there. When i put the car in neutral the vibrations go away. I am not sure wheather its idle related or a bad motor mount. I changed my fuel filter last year. Ever since i had the car in 02 its always had some vibration and hesitation. Any ideas?
Since you don't have after market mounts in there .. I would check the motor mounts .. with it being an auto there is really no pressure on the mounts in park or Nutreal, but once put into gear D or r it will put pressure on the mounts. Have someone check them with you.
<img src=http://domestictuners.com/banner.jpg WIDTH="400" HEIGHT="75" /img>
Hit 200 NA it broke once, Hit 213 it broke again,
Hitting 300 NA is further away than I thought.
