2004 Maxima - Maintenance and Repair Forum
2004 Maxima
Wednesday, November 23, 2016 7:01 PM
I have a 2004 Nissan Maxima that is having fuel problems, it will turn over but will not start. Sometimes I have to pump the throttle and it will start, other times it will work fine. Just started this a couple of week ago. It is a 3.5 litre 6 cylinder. Thanks for any help given.
Re: 2004 Maxima
Friday, November 25, 2016 10:27 PM
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjgut6548XQAhXD4yYKHfLbBu0QFggbMAA&url=http%3A%2F%2Fmaxima.org%2Fforums%2F6th-generation-maxima- 2004-2008%2F605881-maxima-hard-start-when-warm-no-codes.html&usg=AFQjCNFak10v9Pwisz_TWhNThpQt3IAq7Q&bvm=bv.139782543,d.e Had you just Googled your cars symptoms you would have come across this site with some Good ideas to fix your car.I personally think it would be the crankshaft position sensor prior to doing the search myself.Granted another post indicated it could be your coolant temp sensor as well.Just DO some homework and read up prior to buying the wrong component or taking it to a shop to really get the cost UP.I do believe this will help.It is just that when a problem with a car pops up do the research as the internet has loads of information and if it is a problematic issue it will show up in a site or link in most cases!I
