Hi
Working on this Cavalier Ecotec 2.2 for a family friend
I would like to know if there is a head removal and install tutorial with pics on this forum
I have found bits and pieces of this procedure online, but not an entire weight up..... If someone could point me in the right direction I would appreciate it, or provide some key words to put into the search box that will bring up some results, that would be nice too
Thanks in advanced
thanks!
Everyone should wrench!
I have question
what is the procedure on removing this engine bracket?...it is in the way of me getting to the Hex bolt that I need to remove so I can get to the the guide bolt. I have search all over and can't find any info on this, lots of other Ecotec 2.2 that don't have that bracket in the way of that Hex Bolt
thanks for any information. I have tried several way to remove that bracket, but it's still there, hope I don't have to remove the engine
also I don't have a raised area on the timing cover that I needed to line up the notch on the damper with, strange, however I do have the key way at 12:00 and the crank sprocket dot at 5:00
and I don't think it will be any problems
