Hey guys. So my cavvy is dying randomly and throwing both p0335 and p0341 codes which are crankshaft position sensor and the crankshaft position sensor. Ive replaced both, neither helping. Any suggestions folks?
Ok, so i meant p0341 refers to the camshaft position sensor and p0335 refers to the crankshaft position sensor. Pardon my inability to think and type coherently lol. About two years ago i replaced the ignition module and the ignition coil housing when attempting to fix a different problem with it dying randomly. As it is throwing codes, I doubt that it is a mechanical fuel problem such as fuel pump, filter, injectors, etc... I checked the spark plugs, and re-gapped them while i had them out, they looked fine. Any and all help would be greatly appreciated.
It also has hard starting problems. That particular problem started a few months ago and has progressivally gotten worse. The codes are also Intermittent. Any ideas?
