Hey guys went to start the car to leave for work car started right up then I forgot my case cutter, come back nothing . However the fuel pump primes right up all the gauges work and lights on . My question is could it be the icm or it acted almost like I didn't push the clutch in ? However when I got it to crank over it was acting like it was flooded and then would just turn over ? Any ideas?
You can shut the fuel injectors off by holding your foot to floor and cranking. This should clear out any fuel in the engine. While your cranking, take your foot off the pedal and it should start. (unless you have some other issue)
Ron is correct in the "clear flood" part of the PCM programming.
