maintenance on 2001 sunbird - Maintenance and Repair Forum
Wednesday, March 21, 2012 1:16 PM
Hi all. I just purchased a 2001 sunbird with the 2200 engine. It has 114,000 miles. What maintenance should be done? The only think I know that has been done recently is replacement of the injectors. Should I change out all fluids? What about timing belt and water pump? Thanks
Re: maintenance on 2001 sunbird
Wednesday, March 21, 2012 1:28 PM
they stopped making the sunbird in 1994... if you mean sunfire, then yes, oil change, coolant flush, brake fluid flush, power steering flush, change the fuel and air filters, timing set is a chain with a tensioner, not a bad idea to change it every 100,000 miles, water pump is cake on that engine, just do it. have the starting/charging system tested. serpentine belt and tensioner are a must. check the hoses for any cracks, bulges, leaks, etc. change the thermostat.
Wednesday, March 21, 2012 7:04 PM
Yeah, sunfire. Thats the ticket.
