vapor lock? - Maintenance and Repair Forum
vapor lock?
Sunday, August 28, 2011 7:36 AM
hey. just put a fresh 2.4 in my 99 cavi. first time ever swapping a motor. i had a guy said he would help me with every thing but he never showed up so i did it myself.
i guess i put the anti freeze in wrong and i'm having some serious vapor lock problems, maybe i have something hooked up wrong some where. i changed my thermo stat and that didnt help.
the car gets a bit above 90* but it doesnt overheat and my fan keeps blowing fuses. it never kicks on at all. i drained it the best i could to try and start over, filling it slowly with just water to see if i could get it work, but when i drive or rev it up a bit it starts spitting out all the water like crazy either out the cap if its not on or through the over flow. the car runs great other then i got real squeaky pully. the heat does work. i messed with it for 2 days trying to get the water and coolant to just stay in but its not working. some think its a head gasket but i hope not.
im checking here to see if any one could know whats up or any ideas, and if not then i'm going to take it to a shop. thanks
Re: vapor lock?
Sunday, August 28, 2011 8:27 AM
Thats weird. Normally vapor lock is referred to V8's with mechanical fuel pumps on the block that get hot and actually create a vapor pocket in the fuel line while driving slow and then the car almost stalls when you stomp on it from fuel starvation.
If the fan fuse is blowing out I would bet that the fan is getting jammed on something and is unable to spin. Are you sure you put the coolant lines in correctly?
Sponsored by: Kronos Performance
Re: vapor lock?
Sunday, August 28, 2011 8:32 AM
i have no fuel problems, just coolant not staying in the motor. like i said first time ever doing this, i thought i put every thing where it should be but not sure. fan spins freely.
Re: vapor lock?
Sunday, August 28, 2011 3:22 PM
First test your fan motor with some jump cables see if it runs. Sounds as if your fan motor is shorted or there is a short in the wiring. It happened to me once that the coolant was bubling and coming out by the reservoir cap it was the fan motor connector I replaced it and never again...after you got your fan motor working correctly if the car still overheats I would take out the thermostat and try the car without it, Good luck.
Re: vapor lock?
Saturday, September 03, 2011 6:12 AM
i took it to a shop. the fan still doesnt work but i guess my coolant jug had a crack or something like that in it and it was making it over heat. ill figure out the fan today thats for the tips!
Re: vapor lock?
Monday, September 05, 2011 6:32 AM
i swapped and wired a good fan to a switch. my car is still spitting out all the coolant but it does not over heat. the shop i took it to isn't open today and hasn't been all weekend.
i need my car for school tomorrow morning. its an hour drive there and back.
can any one find my a diagram of the cooling system, where all the coolant lines should be run to and what not, and maybe a fan wiring diagram. or direct me to where i can find this info, just so i can check if i have all my stuff right..
one more question. right by the starter, on the tranny, there are 2 bolts for ground wires i believe, one of the grounds is black and the other one has 4 wires on it, there are 2 yellow and 2 black i think. is it possible that these shouldn't be grounded? the 2 yellow and 2 black are all connected together so all of them go to the same place.
i had some one help me take the motor out, so i'm not sure if i put them back in the right spot. thanks
