2.4 engine removal - Maintenance and Repair Forum
2.4 engine removal
Monday, August 02, 2010 10:08 AM
what would be the best or easiest way to take the motor out of a sunfire gt ? do i follow the haynes manual or is there a better way
Re: 2.4 engine removal
Monday, August 02, 2010 10:41 AM
Unbolt the transmission from the motor, Take the hood off the car, Then unbolt the engine mounts and wiring harness, chain the engine, then lift with the engine hoist. Then youre good to go.
Good Luck.
Monday, August 02, 2010 11:23 AM
so you dont have to pull tranny with the motor i didnt think there was enough room to seperate them
Monday, August 02, 2010 2:21 PM
no you don't have to we just finished pulling mine out sat. it took all day it was tricky the motor mounts are easy but the bolts to the trans a re a lil harder also the starter need to be out and the bolt in the flywheel need to be token out i took 3 of us and a pry bar to get it out after we did it i thought that i would have been easier to pull it all out but what ever you do organize know what bolt go were
Monday, August 02, 2010 6:17 PM
i did a search on it and came up with someone saying that you have to pull both on the 2.4s ive also had people tell me to take the engine out from underneath i just want to figure out whats going to work before gettin my hands dirty so you sure its possible to take out the motor only
Tuesday, August 03, 2010 1:07 PM
When i rebuilt my motor i dropped the engine/trans from the bottom.Easiest way in my opinion.
Peter
Gm Stage II W/2.79" Pulley
K&N Drop In Filter
Custom Magnaflow Dual Exhaust
Wednesday, August 04, 2010 6:43 AM
how exactley do you pull it out from the bottom
Wednesday, August 04, 2010 7:06 AM
lower drop is tougher i think. u first need to get the car super high n then u remove the subframe bolts and the upper mount and trans mount and struts to drop out.(did this in the junk yard). now when i pulled out the other 3 engines we did it by taking the motor and trans out on a angle threw the top and then swapped trans outta the car easier to do more room. then dropped the whole thing back in. u will need to disconnect a lottta stufff. plan on if u never did keep ur weekend free.
Wednesday, August 04, 2010 6:01 PM
Its always seems to be tough at first. Once you have done it, Its easy the next time go around. I prefer the taking it out from the top easy way in my opinion.
good Luck.
Wednesday, August 04, 2010 6:14 PM
thanks for the help everyone . i have everything disconnected and labeled now its time to put the hoist to work
Friday, August 06, 2010 1:31 AM
Its really easy, I pulled it out in a little under 2 hours. Just take off all the accesories, unbolt the trans, and motor mounts, and pull it from the top. Its pretty easy. Make sure all the wires are off the engine, pull the battery. Just disconnect the exhaust header from the engine, you dont need to pull it off the car. Other then that, just yank the engine. It isnt as hard as you think. Goodluck.
