trac off and abs light on???? - Maintenance and Repair Forum
Tuesday, June 16, 2009 11:11 AM
so on my 2004 2.2l cavi ls when you crank it up everything is ok. but when you drive off it will shudder like its struggling to move sometimes... and also it will sometimes say i have low trac and the trac control system comes on, but it always down the road The ABS light will come on and my Trac Off light comes on.... any suggestion .pls
Re: trac off and abs light on????
Tuesday, June 16, 2009 6:28 PM
same thing happened to me in my 03 and my fuel pump died like 2 miles later so my guess would prob be fuel pump is starting to go out, id change ur fuel filter first and check to see if that is clogged at all
Tuesday, June 16, 2009 9:06 PM
Andrew43420 wrote:same thing happened to me in my 03 and my fuel pump died like 2 miles later so my guess would prob be fuel pump is starting to go out, id change ur fuel filter first and check to see if that is clogged at all
the traction control and abs has nothing to do with the fuel pump. i'd start by backprobing the wheel speed sensors and see what they do.
87 Firebird
All stock...........lol.
Tuesday, June 16, 2009 9:17 PM
There is a issue with the ABS Jumper harness, it will throw a code like the left front wheel speed sensor is bad. It turns out to be that it's a bad jumper harness, and there is a TSB for it.
Wednesday, June 17, 2009 9:22 AM
randizzle what do you mean by back probing and to the 01 cav what is a tsb??
Wednesday, June 17, 2009 10:46 PM
Im thinking he means using a multi meter to check for continuity in the wires..... and also visually inspecting them
Monday, October 05, 2009 3:09 PM
I found my issue on the abs harness, its right at the plug on the drivers side sensor, pull on the wires, my yellow wire broke off of the plug.
Tuesday, October 06, 2009 8:11 AM
I had to replace this.
