when i turn my car on it starts up but right away the rpms drop and if i dont hit the gas to rev it and get the rpms back up for that half a second the car will die
what could be the problem
Blacked Out z24
http://www.flickr.com/photos/32942255@N05/
any check engine light?
8 psi with m62 and IAT under 100
feul pump going out? injectors need cleaned? feul filter
I was about to suggest Injectors. Go get a "Black" bottle of the STP Fuel Injector cleaner. You can get it at Walmart, if you have one nearby. I would change the fuel filter as well, if you are unsure how old it is. It takes no time and is an easy and cheap swap out.
SOLD!!!!!!!!!!!!
