motor started knocking im guessing pushrods idk this is what my friend said it could be it happend tonight coming home i turned the car off turned back on started making aloud noise im really no mechanic lol would have to possibly rebuild bottom end. in going with worst case think eithier sell the car ( i dont really want to ) or swap the motor i wanna do a 2.4 swap anyway but i dont know how much it will run me. any advice would great thanks guys
... this is being if it is the worst case im going to look it over tmrw morning to make sure maybe its something minor hopefully it is really suckkss as of now i really dont know what it is it could be ANYTHING right now prob right now leaning to a swap cars motor is beat to hell anyway
It could be a lot of things try to find out where the sound is coming from. However if you are no mechanic as you said I wouldn't start off with an engine swap. Plus we need to know what kind equipment you have so help us help you.
The proper way of using the word seen. It is not I seen it that would be I saw it. He has seen the car is the right way to use the word. English class is Cool. By the way thats my sig
update-
i start my car this morning i still hear the sound i let it warm up went away so iwent to go picvck him up then belt starting making a sound then went away so then we stop get some food im opulling away i hear the noise again but sounds diffrent then the one from last ngiht i stop the car get out coolant everywhere belt came off but it didnt snap came off the tensioner so now its sitting n burger king parking lot untill tmrw sop far crappy thanksgiving
i wasnt planning on doing the engine swap myself lol
mike98 cavi wrote:update-
HUH?!?!?!?! Did you pass high school english?
mjy bda bor i wil go bak toio lern sory thks fror tehe adivce
i wrote it in a rush wasnt paying attention next time i will spell check everything so everyone can understand
So your water pump exploded??? that is the only think I could think of to get coolant everywhere when your belt comes off.
yeh its the water pump but i have a feeling something else is going to be wrong too
Water pumps can make lots of noise when they're letting go - hopefully that's all that was wrong. Make sure you replace the belt at the same time, and clean off the pulleys so that the new belt isn't covered in coolant as well.
If you have a shop doing this, then hopefully they'll do that for you. As long as you didn't overheat it, then your thermostat is still likely fine. If it DID overheat, then I would change the thermostat while it's drained. They often fail soon after suffering an overheated condition, so it may as well get done while things are apart and drained.
John
the water pump in the 2.2 is the easiet one ive ever done. just 4 bolts and a gasket, and the pump is only like $25 at o' rileys or autozone.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
yeh i work its really cheap ui looked at it i was like wow lol so its not to big of a deal
