Hello
I have searched the forums for this problem, leans towards the strut mounts.
When a hit a bump, the front end will clunk, also making left or right hand turns it clunks a lot worse. Have had vehicle in air on lift, the sway bar links are fine, the bushings are fine, the front end is tight.
So basically just strut mounts is all it can be right
i its when you turn, it could be a CV joint, strut mounts, or a combo of both. likely only mounts tho.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
