Bad PCM? - Maintenance and Repair Forum
Bad PCM?
Friday, September 12, 2008 8:37 PM
OB2 scanner wont load anything... wont even turn on when connected to my brothers 01 z24.
He has a sputtering and surging problem that I decided to look into for him.
the scanner works fine on my 05 w/sc flash and also on my gf's 96 z24
Can I swap the pcm from the gfs to my bros to check?
Re: Bad PCM?
Saturday, September 13, 2008 11:09 AM
no you cant swap them out the 96 and 01 pcms are completely different plugs.
Re: Bad PCM?
Saturday, September 13, 2008 5:40 PM
Before you swap the pcm, check the fuse for the cigarette lighter. If it is blown the lighter as well as the OBD2 connector will not get power. My Sunfire had the same problem when I bought it, and replacing the fuse solved the problem.
Jim
