start with the shaft i had to remove the rubber/steel weight on the shaft after installing the 3800 as it rubs on the oil filter adapter NOT THE FILTER THE ADAPTER so don't tell me to relocat it cause these piece has to stay there (pressure sensor is in it)
bearing i get this clicking noise (not shaft) i will be goings straight and it will only click when the cars weight is on a bad ball i know this cause i had the car in neutral and pushed it and everytime the wheel hit a certain spot (SAME SPOT EVERYTIME) i would get a clicky crunching sound liek a ball bearing fell out of the cage that there in
could removing that weight thing chew up bearings or will it just cause some vibrations
i have had no vibrations up till this bearing issue
JBO since July 30, 2001
