hey whats up i just put a another 2.3 motor in my car two days ago because of a bent rod, after i put the motor in it started and ran fine for about 24 hours, then as i was driving it just turned off. i tried cranking it and it woud not start then eventually after about 2 mins it started. i drove about 3 blocks then it cut off again but this time it would not restart, the starter spins but the engine is not even close to starting. im thinkink maybe its a sensor but im not sure, when i try to crank it the check engine light flashes, also does anyone know what type of scanner i could use to scan fo a trouble code, its a 95 z24 2.3, thanks
if it can't win a race it better win a show
