03 Sunfire Headlight help - Maintenance and Repair Forum
Monday, April 14, 2008 10:17 AM
Alright I started out with the dim/dull passenger side headlight (whether on high or low beam). I have read on the forums that it means the orange wire is corroded somewhere. I couldn't find find where it was corroded quickly so I tried running power off the drivers side headlight for the time being to give me headlights (another guy said he was doing this as a temp fix). Well that went great and blew both headlights out today. I soldered then connections so I know all connections are good and correct, I checked a million times. But I was looking for more suggestions on the fix. Am I best off to dig and dig until I find the corroded wire connection or is there a way to wire the headlights for a quick fix. Suggestions on common corrosion spots would be great too! Thanks.
Re: 03 Sunfire Headlight help
Tuesday, April 15, 2008 11:30 PM
could be the relay. check that. should be in the fuse block on the side of the dash
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
