Okay people... I have a question.
I was always under the impression that when your turn signal blinks really fast, it means you have a bulb out somewhere. I checked all my bulbs and none seem to be out. Could this be a fuse or something?
Any ideas would help.
Thanks.
<br><a href="http://www.angelfire.com/clone/jenivegas/index.html"><img src="http://images.cardomain.com/member_img_a/240000-240999/240298_44_full.jpg" border=0></a>
are you sure both stages of the bulbs are working? all the bulbs (except the tiny 194s on the cavaliers) are two stage, when they're on, they're either bright or dim, not on or off.
Have you replaced any of the bulbs with LED bulbs? If so you need a variable relay for your blinkers. The whole flashing faster thing works on resistance. Light bulb burns out, less resistance, relay works fast. As we all know LEDs have very little resistane so if you dont change the relay, it will think you have a light out and blink fast
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
