Weird Problems - Maintenance and Repair Forum
Weird Problems
Wednesday, October 24, 2007 8:18 PM
So when i turn my wheel a quarter of the way to the left and to the right my steering wheel kinda pops i can not hear as much as i can feel it and sometimes i can feel it down on the pedals its weird i checked the power steering fluid and added a litle but i added a little to much so i pumped some out and it was dirty i dunno why. And also when i have my window down and i start off in first in second gear and kinda get after it it sounds kinda like a plastic wrapper is flapping in the wind
any help would be great
***Looking for a BLUE 03+ STOCK cavi wing pm me if ya got one you wanna sell***
Re: Weird Problems
Sunday, October 28, 2007 3:55 PM
That popping could be the intermediate steering shaft in need of lube, there is a kit available from the dealer that takes care of that, or a bad strut mount, or even your tie rod ends. Grease the tie rod ends, see if that helps any.
Re: Weird Problems
Monday, October 29, 2007 5:29 PM
ok thanks man i will try that
Re: Weird Problems
Saturday, November 03, 2007 3:47 PM
the "flapping" sound it most likely the seat belt flapping against the 1/4 panel trim. same thing happens in my car with the window all the way down, if you roll it up about 2 inches it stops.
http://registry.gmenthusiast.com/images/my2005cav/my%20car%20the%20bash.jpg
Re: Weird Problems
Tuesday, November 20, 2007 10:21 AM
try looking at the lower A-frame bolts i had the same prob on my 2000z24 but in order to check if its loose you have to remove the pitman arm,try to tighten it if it dont tighten then u need a new one,but make sure you put a second jack on the A-frame.
1.remove tire
2.place 2nd jack lightly under a frame
3.5/8 socket remove the pitman arm bolts
4.try to tighten the bolt in between the steel faceing the bumpers
5.replace it if nessery
