so there is a crack in my washer fluid tank and it wont hold any fluid. So is there a way to fix it so that i don't have to buy a new tank!
You could try GOOP or some silicone sealer
go to a junkyard and pick up a used one, might as well fix it right
I had the same problem about 2 months ago. the crack was pretty close to the bottom of the tank, so it held almost no fluid.
i used some epoxy glue, put that on, and about 1 hour later was full strengh. it has not leaked since.
Yeah, that should do the trick. I would scuff it up with some 150 grit sandpaper first, though (or even a lower grit)
oh yeah
i did do that too, but i forgot to mention it.
thanks for pointing that out
I went and got a used one from the junker but i havent had a nice to install it!
