Engine lean problem? IAC TPS? - Maintenance and Repair Forum
Friday, October 12, 2007 2:01 PM
Okay heres my whole story. I rebuilt my 2.3 Quad 4 top to bottom new crank pistons rings rods bearings valves guides lifters yada yada everything it ran great for about a year thank god it cost me an arm and a leg. Then on my way to court it started to miss fire. So i went home and checked and i was right to an extent. When i pulled the plugs the center electrode of my number 3 cylinder was gone i thought okay the dude at napa dropped it and it broke so prayed that it went out the exhaust valve and put a new plug in 2 days later the same thing in the same cylinder. Consequently the head gasket blew and what seemed to be a lifter tick transpired.Luckily i had an extra head lifters cams everything so i installed that with a new head gasket and everything did a perfect job but the cars runs like poop still
Problem: The top end still seems to tick the engine runs like crap it runs real ruff at low rpms the rpm fluctuates up and down and sometimes stalls still has a lifter tick in what appears to be the same cylinder? Also when i drive it the car wont shift normally and wont down shift when u stomp on it please help i'm lost it runs very lean as well.
Thinking maybe IAC TPS or fuel filter?
Re: Engine lean problem? IAC TPS?
Monday, October 15, 2007 9:12 AM
its something in the engine, the computer is just throwing you off
compression test on each cylinder, and check your valve clearances... might be a bent valve too
t
Tuesday, October 16, 2007 8:55 AM
Not downshifting on WOT is in the engine?
I doubt.
That's a classic TPS problem.
2002 Cavalier 2200 5spd
