2.4 motor knocking :( - Maintenance and Repair Forum
Thursday, July 19, 2007 10:27 AM
so we thought it was the timing chain tensioner that was messed up (sounded like the timing chain was smacking the case) so we pull that apart....its fine....now we are stumped.....my mechanic swears its not the wristpin...he said when he put his hand on the case you could feel the tapping clear as day.....didnt do it at idle...only wen i reved did it make the noise....any ideas?
you scratch my ride IMA EAT YO CHILDREN
Re: 2.4 motor knocking :(
Thursday, July 19, 2007 7:35 PM
Its prolly #3 rod bearing.
My car--->http://www.cardomain.com/ride/2569452
Thursday, July 19, 2007 9:07 PM
a rod bearing would do it at idle though....no knockin at idle wiht my car....and now it starting to run like crap when idling so i think i didnt sumtin to a valve....maybe a valve spring
Friday, July 20, 2007 5:14 PM
I had the same symptoms as you. It did NOT knock at idle and it was a rod bearing. I pulled the oil pan and found metal all in it. I found very little metal on the drain plug.
Monday, July 23, 2007 1:11 PM
ok so i got ahold of a 2000 Z24 cav.....to do the swap to my 98 2.4.....i would just need the motor and ECU correct? is there anything else special i will need?....im gonna love this cause now i can do a supercharger reflash
Monday, July 23, 2007 3:51 PM
16 Valves Of Power wrote:ok so i got ahold of a 2000 Z24 cav.....to do the swap to my 98 2.4.....i would just need the motor and ECU correct? is there anything else special i will need?....im gonna love this cause now i can do a supercharger reflash
You don't need the ECU to put the 2000+ motor in your 98. You use the 98 wiring ECU, injectors, EGR, exhaust, and exhaust gasket. To put the 2000+ ECU in you need to swap all the wiring over because you need the BCM from the 2000 cavy.
Monday, July 23, 2007 4:24 PM
ok good to kno thnx
