o2 sensor - Maintenance and Repair Forum
o2 sensor
Tuesday, May 01, 2007 4:43 AM
I was needing to know how to replace my o2 sensor, where it is, what kind of tools I need, and how difficult it would be to do myself. thanks.
02 sunfire
p0130
o2 sensor
circuit malfuntion
bank1 sensor1
Re: o2 sensor
Tuesday, May 01, 2007 8:07 AM
This is what I used. There are cheaper and other ways to do it, but these are kinda the "proper" tools to use. The special socket just has a slit in it to go around the wire harness. I like using breaker bars to get them out because they are super tight from constantly getting heated and cooled.
You definately should do it yourself, it is so easy. Just follow the exhaust manifold back and you should see it.
Wait for someone else to chime in, but I think sensor one is the one in the manifold. There is a second one behind the cat, but I think that is sensor two.
"The Blue Bullet"
Re: o2 sensor
Tuesday, May 01, 2007 9:13 AM
how far are either of them under my car, I only have a pair of ramps , and I don't usually like getting under there unless it's to change my oil and I don't even like doing that.
Re: o2 sensor
Tuesday, May 01, 2007 9:16 AM
The primary one is in the engine compartment, on the exhaust manifold. You don't need to go under the car to access the primary one. If you don't have a socket like that, just use a wrench that fits it....7/8" IIRC.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Re: o2 sensor
Friday, May 11, 2007 9:50 AM
does anyone have a picture of exactly where the o2 sensor is so I know what i'm pulling out, I don't want to end up pulling something else out in the process since this will be my frist time changing it. thanks
Re: o2 sensor
Friday, May 11, 2007 12:17 PM
its easy to find. you should only need to change the one on the manifold, its the one that affects driveability of the car.
Re: o2 sensor
Friday, May 11, 2007 1:35 PM
so i guess that's that cylinder bolt thing that's going into the headers right?
Re: o2 sensor
Wednesday, May 16, 2007 11:34 AM
Look for the plug looking thing screwed into the header/manifold with the wires coiming out the end.
