Bad clunking noise from 97 sunfire - Maintenance and Repair Forum
Tuesday, March 27, 2007 6:10 PM
Hey guys/gals, my 97 sunfire is back with another problem . I am getting an awful clunking noise on the driver side rear whenever I hit a bump or brake/accelerate. It's something like "ku-clunk" if you could understand . It only happens when it's dry out, if its wet outside, the noise goes away, so it's almost like a lubrication problem but I have no clue. It really loud, and I can hear it over my music. Anyone have any ideas?
Re: Bad clunking noise from 97 sunfire
Tuesday, March 27, 2007 6:19 PM
might be bad strut mounts in the rear, my 96 cavi has similar probs.
96 Cavalier base
2.2l manual
Wednesday, March 28, 2007 9:31 AM
You should check your drum out on that side and spray it up with break cleaner....also you should auto reset the breaks.
Wednesday, March 28, 2007 6:43 PM
I had a similar problem when I installed in struts. It was coming from the passenger rear. So I got new strut mounts and after a day everything was cool. Then a couple of days later the noise was back but now on the driver rear. I can't figure it out. I reseated everything and tighen everything no clue.
Tuesday, April 03, 2007 5:51 AM
Haveing the same noise problem, replaced rear shocks and noticed the upper strut mounts were destroyed, replaced them and everything was better. All in all $40 for each shock, and about $20 for the upper strun mounts and mounting parts. No more noise, thats all that matters...
