Dident have time to search this out but i seen somewhere that this is common i got a cly 1 injector problem it cuts in and out i can tap the injector and it work fine but somtime it cuts in and out ???? Is this an easy fix or not i replaced the injectors and still the same thing any info would be great thanks guys !!
Ron...
ya only first injector closest to the passenger side of the car i just did the coils plugs and wires as well still same thing !
Ron...
You may want to make sure the 12V is getting to the #1 Injector. And also that when the PCM pulses the ground, that it gets all the way to the injector. Have a good look at the connector for the #1 injector. It may have a corroded connection, or one or both wires may be almost broken through. If the injector connector is good, then you may have bad/corroded splices in the engine harness. That was what I found with mine. A bad splice on the 12 V wire on the main harness behind the engine, prior to the split splice for the 4 injectors.
