97 2.4L - Wont Idle correctly at low RPMs - Maintenance and Repair Forum
Monday, March 12, 2007 12:19 PM
Car starts fine...car runs fine when you hold the throttle down...sounds great...but when you let go of the throttle it idles rough and/or dies. It idles fine at a cold start for a minute or so then as the car warms up it gets worse till it just wont idle at all and dies unless you hold the throttle down...
No check engine light.
It has new plugs / boots / packs
Any ideas?
Re: 97 2.4L - Wont Idle correctly at low RPMs
Monday, March 12, 2007 12:31 PM
Throttle postion sensor? That's what mine was.
Ideas?
Monday, March 12, 2007 1:57 PM
Replaced it aswell.
Tuesday, March 13, 2007 5:16 AM
is it running really fat? I was working on a saturn the other day( i know i know) that the only way you could start it was with the peddle on the floor. Turned out to be the ect though it was -40 all the time and was wadding the fuel in. Also check your iac.
