headlights or maybe a drl prob - Maintenance and Repair Forum
Wednesday, February 07, 2007 4:51 PM
heres my problem i have a 99 z24 and about 1 year ago i disconnected the brights on my headlights (i rarely use the brights) to get rid of the drls. somehow it worked everything worked fine but i always had that annoying light on the dash. but i dealt with it now after a year something changed now the drivers side is the onlly one that works. so i thought hell just reconnect the brights. it kinda worked but the passenger side is way dimmer than the drivers side plus the drls are always on.i havent really checked anything cause its been cold outside an ive decided to rely on other transportation but seeing as i go to work when its dark an come home when its dark(pus i dont want a ticket) i thought id come here an ask maybe a few ideas will send me in the right direction.thanks
Re: headlights or maybe a drl prob
Wednesday, February 07, 2007 5:32 PM
check fuses?
Also there is a easy way to disable your DRLs by removing your dash and finding the correct wire in the cluster wire loom, you just cut that and cap it off so it dont short out to anything and your done.
as for ur headlight problem you might want to check ur fuses and get back to us
being that u didnt mention youve done any sort of headlight swap that shouldnt be your problem, just sounds like a simple fuse being blown.
Sunday, February 11, 2007 2:30 PM
ive checked every fuse (and even though i didnt mention it ) i even put the stock headlights back in same problem when i tur the headlights on the brights also turn on but dimmer and the right side is also dimmer i also noticed that if i try to turn my brights on it doesnt work they will flash but not stay on an i know it soundws like a fuse problem but i cant find a burnt fuse anywhere please help and thank you
Sunday, February 11, 2007 2:44 PM
don't forget to check the wiring harness under the battery tray, it could be rotting away on you as well
