A/C Motor Noise - Maintenance and Repair Forum
A/C Motor Noise
Friday, January 26, 2007 7:14 PM
ok lately my car's blower motor sounds like something is stuck in it cause it sounds like a jet is takin off when i turn the heater on full. i tried to look under the dash and see if i could remove the blower but i couldn't find anything there that can be removed. i did notice that there is a tech bulletin out about something like this so i was wondering if anyone else has had this problem and how they fixed it.
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
Re: A/C Motor Noise
Sunday, January 28, 2007 8:35 AM
Probably something in there. I had a handful of leaves the last time I took mine out (convertible). Take the passenger under-dash panel out. Then it's just 3 7mm screws holding it on. Wiring plug is on the back side.
Re: A/C Motor Noise
Sunday, January 28, 2007 8:41 AM
i looked underneath and it didn't seem like there was anything i could remove. the haynes book said the same thing but i guess i'll have to look a lil harder thanks for your help
Re: A/C Motor Noise
Tuesday, January 30, 2007 8:25 AM
I recommend removing the passenger side seat to get better access to check that part. When you remove the seat, place some cloths over the bolts.
Re: A/C Motor Noise
Tuesday, January 30, 2007 7:04 PM
Check the first two stickys
