P0341 Trouble Code: Camshaft Position Sensor - Maintenance and Repair Forum
Monday, January 08, 2007 3:19 PM
Hi ppl,
I was driving my car the last night and the Check Engine Light came on... turned off the car, turned it on again and it was still on. After driving for a few minutes, the ABS and brake light came on for less than a second and the Check Engine Light went off...
Scanned it today, and got the P0341 Trouble Code: Camshaft Position Sensor Performance. btw, I have it deleted right now, but don't know if it will come on again.
What does it mean? Do I have to change it? Clean it? Repair it? Where is the location of the sensor?
btw, I'm having to hard depress the gas pedal while turning on the engine. Sometimes have to try 3 times, because the engine shuts off at idle. Is that sensor causing me those problems?
Thanks for your feedback!
Re: P0341 Trouble Code: Camshaft Position Sensor
Tuesday, January 09, 2007 12:31 AM
My guess would be youre Camshaft Position Sensor, Is starting to fail on you. Its time for it to be replaced.
Tuesday, January 09, 2007 8:00 AM
If the wires aren't damaged, the only thing you can do is replace the sensor. Not a bad idea to get one now, if only for backup. It is possible what may have happened is simply a hiccup glitch.
Tuesday, January 09, 2007 9:05 PM
Thanks for your feedback...
but... where is located? and the symptons are due to a bad CPS?
Thanks
Tuesday, January 09, 2007 11:08 PM
An Intermittent problem may be caused by the following conditions:
-A poor electrical connection
-Rubbed-through wire insulation
-A broken wire inside the insulation
Check any suspected circuitry for the following conditions:
-Backed-out terminals
-Improper mating
-Broken locks
-Improperly formed or damaged terminals
-Poor terminal-to-wiring connections
-Physical damage to the wiring harness
Crankshaft Position (CKP) Sensor
Rear center of engine, to the passenger side of the coil packs
Thursday, January 11, 2007 12:19 AM
Thank you Kardain... but wasn't the Camshaft Position Sensor? or it's the same thing? :S
Thursday, January 11, 2007 6:40 AM
image copyrights 1999 chiltons automotive books, a division of haynes north america
honestly, if you ever venture into the maintenance forum, you should get yourself a repair manual. it will lead to a deeper understanding of your car.
Thursday, January 11, 2007 11:33 AM
underground wrote:Thank you Kardain... but wasn't the Camshaft Position Sensor? or it's the same thing? :S
Right info, wrong sensor name... I haven't been getting much sleep this week
Friday, January 12, 2007 10:06 AM
Thank you guys. As always, your information is so valuable...
