Hi,
My rear window defroster has stopped working. I have used a DMM at the switch and it seems to be functioning fine there, ~12V on the purple wire when the switch is in the on position. I have also checked the plugs at the grid it has a resistance of about 1.2 ohms and is grounded on one side. Now for the kicker if I unplug the non-grounded side and check the voltage I get 12V however when plugged back into the grid I get nothing. The fuse is fine so I am assume there is a relay or something between the switch and the connector on the grid which would be stopping enough current from reaching the plug, however I am not sure. If anyone has any suggestions and/or wiring diagrams that would be great!
Car: 2000 Z24, 5spd
PS: I've been looking for wiring diagrams a few times so if anyone has some that are not even relevant to me it might still be useful in the future.
Thanks alot
thanks for the reply.
I did search before posting and found those and a few other posts however it does not appear the connector seems to be fine in my situation.
I'll try and trace it tomorrow. But if all else fails I guess I will just run a line, will it be safe to splice the purple wire from the switch and run it back to the defroster?
Hey guys...i had this problem with the defogger not working...looked through a Haynes manual - useless...couldnt find a Chilton...wasnt sure what wire or what side the power would be. Did a search and the issue is now resolved. Thanks for the inputs on this forum and a few others. Simple fix. Much appreciated
Les
