Anyone with the 2.2 Ecotecs have this problem?:
Theres a vacuum leak sound coming from around the P/S res. it sounds like it has a leak, but ive tried connecting them up again,checking the hoses but it still has the sound. Also does this have anyhting to do with the P/S? Its really hard to turn now, but the dealer says its normal, and i dont remember it being hard to turn, i also have P/S fluid sitting on the box coming from the cap, the levels are normal though
Thanks
http://www.cardomain.com/ride/2267189
if you have a vacuum leak, a CEL normally follows.
Use a vacuum guage to see what it is 19-21psi is normal.
As far as it being harder to turn, low on fluid, or belt to loose would be the first thing I'd check
