Shuddering issues at low rpm city driving - Maintenance and Repair Forum
Friday, September 15, 2006 8:25 PM
This is going to be fun to try to explain... Alright, when I'm driving at around 30mph and the car is about as low in the r's as it will go in 3rd before it will go back down to second (in a 3pd auto, mind you) the car jolts/surges pretty badly. Ok, very badly. It doesn't want to stall at all just jolts the whole engine like im punching the gas reeeeeal quickly...It's pretty much like that feeling when you try to put the clutch in on a standard without enough gas and it shudders real bad ....yeah, thats the feeling. I give it some gas, bring it up around 40mph+ and it's fine. Does this sound like an engine problem perhaps? or more like a tranny problem? My car has 130,000 miles on it and this is transmission #2... So I'm kind of hoping it's not quite time for another rebuild.
Re: Shuddering issues at low rpm city driving
Friday, September 15, 2006 8:39 PM
Sounds like the pump in the tranny is going/gone. Possible it's other like the TC or Bearings, but doubtful.
Saturday, September 16, 2006 3:13 AM
Your torque converter lockup is not disengaging. At speed this bypasses the torque converter to prevent slippage and improve mileage. On the 3spd auto you can remove the plug at the front of the transmission near the radiator. This will prevent the lockup from engaging. You can drive the car with it disconnected but your mpg will suffer. Most times the lockup solenoid is faulty. If the symptoms disappear after the plug is removed this will confirm it.
Saturday, September 16, 2006 6:25 AM
Ernest Schulze wrote:Your torque converter lockup is not disengaging. At speed this bypasses the torque converter to prevent slippage and improve mileage. On the 3spd auto you can remove the plug at the front of the transmission near the radiator. This will prevent the lockup from engaging. You can drive the car with it disconnected but your mpg will suffer. Most times the lockup solenoid is faulty. If the symptoms disappear after the plug is removed this will confirm it.
TCC solenoid is exactly what I was thinking as well.
Sunday, September 17, 2006 1:28 AM
Agreed
...They just HATE it when you ...POINT - LAUGH - then DRIVE OFF AND AWAY-!...
Tuesday, September 19, 2006 4:04 PM
Indeed you are all correct. I removed that plug and the shuddering stopped. My next question, as probably expected: Is the solenoid something I can get to and replace from outside the transmission, or is something that you can only get to form inside the trans? Nonetheless, thanks for the diagnosis!
Wednesday, September 20, 2006 5:55 AM
Go to this site for full instructions on how to replace.
http://autorepair.about.com/cs/doityourself/a/aa100302a.htm
Wednesday, September 20, 2006 6:06 AM
On the other hand, if you feel you cannot do the job yourself you will at least know what the problem is and what is involved. So don't let a repair shop try and rip you off. You don't need a transmission rebuild.
Wednesday, September 20, 2006 6:56 AM
Me once again. You can decide if you want to leave the TCC plug off or not. My nephew drives his Cavalier with it permanently disconnected. He has a 40 mile commute each way every day and says he is still happy with his fuel consumption. In town driving you will hardly know the TCC lockup is missing and your fuel consumption will not be much lower than with it connected.
This is just a thought because you might not want to spend too much time or money on a high mileage vehicle.
Wednesday, September 20, 2006 12:15 PM
This is what I used to change mine on a '93 2.2, less complicated way of doing it.
You will need a new solenoid and possibly a trans cover gasket.
http://www.kichline.com/chuck/fiero/TCC.htm
This article, by Chuck Kichline (Many thanks), gave me the insight into how it works and the confidence to do it.
This is written for a Fiero but is almost identical to ours.
I jacked up the left front and used stands, removed the left front wheel and trim behind it, To remove the lowest trans case bolt I jacked the engine up very slightly and blocked it . A very small amount of trans fluid leaked out, because the unit is tilted to the right.
With the trans cover removed the solenoid can be seen and is held in by one screw.
I checked the trans fluid level after the completion test drive and just added the small amount required.
Hope this helps
Alont
Wednesday, September 20, 2006 12:59 PM
Thanks for that. Does seem much easier now.
Thursday, September 21, 2006 6:59 PM
Thanks a lot. All this info is very much appreciated...Looks like I have something to do this weekend!
Sunday, November 04, 2007 2:50 AM
Have I ever mentioned that you guys are AWESOME?!?! You just saved me a ton of backyard diagnosing. my century is having the same problems, and with that DIY link I turned it into a half hour repair!!
I just customize em, I don't fix em.
http://i235.photobucket.com/albums/ee100/lowfords22/08-30-07_1538.jpg
Sunday, November 04, 2007 10:30 AM
Same prob here with my 4t40e 4 speed,Ill have to look into this.
