car wont start - Maintenance and Repair Forum
car wont start
Thursday, September 14, 2006 1:38 PM
I have had this problem for a min the car just wont start. Its a wait look at my profile so you can see what i have. Its not the clutch sensor or the battery or the starter. I turn the key and at first it was stuttering on start up now it just wont start. Please help me. This sucks.......
Built not bought!
Re: car wont start
Thursday, September 14, 2006 1:41 PM
Sounds like it's not getting fuel. Can you hear the whine of the fuel pump when you turn the key to ON (just before cranking it)?
Rob
Sold 2/2/05
Re: car wont start
Thursday, September 14, 2006 2:34 PM
I agree with redgote.....it def. sounds like the fuel pump. The fuel pump went out of my fiance's 99 neon, and it had the exact same symptoms.....the studdering was it burning what fuel it had left in the lines....if you can find the purge valve on your fuel rail try turning the key to "on" so it primes the pump....then hit that purge valve and see if any fuel comes out....i wouldnt stand infront of it when you hit it though just in case it does have pressure. no fuel pressure = no fuel = fuel pump. atleast thats what ive learned from my experience with my fiances car.
Cavalier z24......A poor man's Camaro....close enough, right?
Re: car wont start
Monday, September 25, 2006 1:45 PM
hello can any one help me ? i need to find the clutch sensor email me at cesar_626@yahoo.com
Re: car wont start
Monday, September 25, 2006 7:41 PM
you didn't get the car from any of the states Hurricane Katrina hit did you,Lol. j/k Seriously check everything you can think of, i'm assuming its a standard so give the push start and see how that goes, take it to a mechanic and see if you get engine codes. Sometimes the hardest problem is solved by the easiest answer. Like any mechanic you can't really diagnose any problem unless the ill vehicle is there to inspect.
Eat my cock you wanna be ricers.
