How to test 2.4l coils? - Maintenance and Repair Forum
Monday, August 28, 2006 3:09 PM
Well,
how should i go about testing my coil pack to see if its spent...and is y im getting a misfire. They look fine... but anyway to test it with a volt meter?
Nate
1995 Cavalier W/2k1 Engine
Re: How to test 2.4l coils?
Monday, August 28, 2006 8:42 PM
test it with an ohm meter on the secondary terminals, the coil should test to be about 10,000 ohms if its out of range then replace it.
_______________________
** Flat Broke Racing Inc.**
Tuesday, August 29, 2006 3:02 AM
Manitoba Motorsports wrote:test it with an ohm meter on the secondary terminals, the coil should test to be about 10,000 ohms if its out of range then replace it.
Can you explain a little more.
Tuesday, August 29, 2006 8:22 PM
i've attached an image here, **SORRY FOR SIZE** but needs to be that big to see it right.
basically just check between the two labeled terminals and your set.
