New owner of a 95 3 speed Sunfire SE coupe.
in overall pretty good shape, Its my new Daily Driver while my SHO is being upgraded and to help save some money in gas. Car has 120K on the motor, and has a few problems. ABS light is currently on, Haven't 'tested' if the ABS works or not, We replaced the brake pads and rotors out front BEFORE the ABS light came on, didn't bled them, drove it a block just to get it home, and the ABS light came on, We bled the brakes and its still on, we figure it might just because of all the fluid in the system and that we have some excess burning off around it.
Second problem is it has a pretty bad Miss below like 2K RPM untill its been driven for like 5 min after which it goes away but still has some pretty serious powerloss at full throttle. I replaced the Air filter, oil, oil filter, and Spark Plugs immediatly after purchase, the missing isn't a result of the new plugs or oil or anything like that. I have new wires, haven't replaced them yet, Couldn't figure out where the distrubter was on the car
Last problem is the transmission, Shifts kind of high unless you let go of the Gas, in which case it shifts perfectly if you time it right. I was told on the other thread it was the TV cable possibly? Any more Details on that, what other names it goes buy? How hard to replace it? etc? Thank you very much in advance for the Input guy! I've been in the SHO community for the past year with my Beast of a 93 ATX SHO, Maybe I can set up some races for my baby on these forums
and I hope to keep getting great input from the community.
Oh, and my Lisence plate Bulbs won't light up, and Yes the bulbs are good and no fuses are burnt out, REALLY lost on that one.
TV cables can usually just be adjusted. Have you checked the compression on it? If the head gasket is leaking into the cylinder it will miss like that. Don't know about the brake problem.
1995 Cavalier 2.2 Liter Auto With 64k Miles
